Intake manifold bolts torque 11ft lb
Ndx
IL
Hey,
I have torque down intake manifold bolts to 11 ft lb
My torque wrench starts at 10 ft lb ...
https://www.cpooutlets.com/platinum-tools-c2fr50f-3-8-in--drive-10---50-lbs-ft--split-beam-click-wrenches/prenc2fr50f,default,pd.html#xsell=prenc2fr50f--2
I guess I should look for a different one for this job ? I know that they are not very accurate at low scale.
Thank you
If you are + 20% should be fine.
Manifold What on?
Story: I recall snapping the cam box bolts on my GF Suzuki 500 doing a valve lash adjustment. Torque to yield.
I had a short ratchet and I was even choked on it up near the head - just running the bolts down PRIOR to torqueing them. Never ran into this situation before with American made engines.
At least I could get (what was left of)them out of the casting with my bare fingers since the threads in the casting werent distorted.
Torque wrenches are generally accurate from 20%-100% of the specified range.
You need to buy a new torque wrench, probably an inch lbs one.
I think you should be OK, especially if the bolts are to be coated with a anaerobic sealant. Get a different torque wrench in in-lbs for those smaller bolts. I use a bike torque key set at 5Nm for smaller screws that the OEM calls for low torque on.
Get an in-lb torque wrench. prob 1/4 drive
preferably not a princess auto power fister.
Originally Posted By: Ndx
Its plastic intake manifold going to alu block ...
Do you guys think that those cheap princess auto torques are suitable for this ?
https://www.princessauto.com/en/detail/1-4-in-dr-digital-torque-wrench/A-p8381477e
or this ?
https://www.princessauto.com/en/detail/1-4-in-dr-click-type-torque-wrench/A-p8653990e
should I compensate for 1/4 to 3/8 adapter ?
PA's Pro Point brand is probably the highest quality available in a big box store around here in Toronto. All of the stuff I have seen is Taiwan made, nicely finished and beefy. I understand why some people argue USA made = Taiwan made > China made when I handle their tools.
I would use it without hesitation.
EDIT: Would a adapter not distort the torque readings?
Adapter would not, socket extensions generally will not but extending the length of the wrench or using something like a crows foot will.
I have read , if you need to use a crow's foot , position it 90 degrees to the major length of the torque wrench ( 3 or 9 o'clock ) .
