@NinjaCivic, welcome to BITOG, and thanks for resurrecting this thread.
Strangely enough, I had no problem removing the harmonic balancer bolt on either of the two Hondas ('77 Accord and '88ish Accord) I've changed a timing belt on. But those are both a long time ago, and perhaps Honda has changed their practice.
But anyway, I have used a couple of methods on stubborn HB bolts. The problem was finding a way to immobilize the engine so turning the bolt wouldn't simply turn the engine over.
1. 1997 Mazda MPV 3.0 V6
I took a piece of scrap plywood and placed it such that one side rested on the ground in front of the HB.
Drilled a hole for access to the HB bolt. Drilled two smaller holes and bolted the plywood to the HB (which had a drilled and tapped hole on either side of the bolt).
The plywood stopped the HB from turning. The bolt broke loose fine.
2. 2005 or so Mitsubishi Lancer
My friend's son's car. We were absolutely stumped. Just couldn't budge the bolt. Finally, with great reluctance, we tried the nuclear option. After thinking about it and reasoning it out about 10 times, we put the socket on the bolt, put a breaker bar on the socket, and bumped the starter. That broke the bolt loose immediately.
Scary, and I haven't had to do it since.
3. 1990 Mazda MPV 2.6
This to remove the timing chain cover, not do a timing belt. But anyway, it was before I had my impact gun.
I pulled the starter motor, wrapped a rag around the end of a crowbar, and jammed the ring gear with the crowbar. Put a section of pipe over the breaker bar, and cranked on the pipe with my R hand while holding the crowbar with my L.
It worked, and didn't damage the ring gear. Phew!
