Originally Posted By: fsskier
Originally Posted By: Scott_Tucker
The truth of the matter is, the fasteners are not likely to fail or fall off if an experienced tech installed them by feel. Torque does is not the final word in whether a fastener is tightened properly, there are a whole bunch of other factors.
Hmmm... I lack your confidence in this. Our SHO Taurus returned with a split mag, a sheared off security lug bolt, and everything else torqued well past 200 ft lbs. I have seen a semi full of warped valve covers, caused by overtorqueing, often by paid mechanics. The aforementioned BMW called for regular detailed service, the exhaust manifold bolts survived the orginal factory torquing, my 12,000 mile and 24,000 mile service performed at home, then were sheared off by the "factory trained, highly experienced) dealer mechanic who was tightening them by feel for the 36,000 mile service.
In all cases above, the customer paid. So, maybe you are right, trained paid mechanics should go by feel.
Also it increases income from roadside service, lug bolts torqued past 200 ft lbs cannot usually be removed by the owners spare tire tools.
I am not saying they are doing it right, I'm saying that is what a flat rate tech must do to survive and that is why flat rate is terrible.
I should say a *good* experienced tech. There are very few good techs out there. I hear you about overtightened lugs, broken off or cross-threaded bolts, etc. I see a lot of shoddy work. Some people should have never gotten in this business. Most mechanics know zero about how fasteners work. This is where theory really comes in handy because it helps you visualize how a fastener should be tightened. The thing I have noticed about lug nuts is that it's not necessarily that they have been overtightened, but that the mechanic did not lubricate the threads, so they gall. When you try to take them off they feel like they have been torqued to 200 lb/ft.
