Installing your own winter tires
SE British Columbia, Canada
For snow areas only. Alabama boys need not apply. Do you install your own winter tires?
It's a task I don't mind.
I use a floor jack, jack stand, wheel blocks, corded electric impact wrench and torque wrench.
When I have the wheel off, I grease any suspension fittings (that have zerks) near the hub, inspect the brake pads, and CV boots, and give the frame a shot of Krown rust preventer. I then check and adjust the air pressure.
I prefer it over a shop because their employees typically go ape with the impact wrench when tightening down the nuts. Just don't get a hernia when dealing with trucks tires.
I did it by hand for a while on 3 vehicles. Have a 1/2 inch cordless impact this year, so I'm actually looking forward to it. For me, it's just as much work to load up the tires and run them out somewhere as it is to just swap em out myself.
The evo I did. The focus I'll just bring it into the dealer and they do it as part of the 'the works' with the oil change and tire rotation.
Every late Fall and Spring. With air tools its not too bad. Usually try to schedule in something with it- brake bleed, check/lube brakes, of course inspect tie rod ends and a little Fluid Film on anything that is, or might rust.
Been swapping tires over myself twice a year on my own car for almost 40 years. I used to break the lug nuts loose with a breaker bar, but since I got a cordless impact, it's much easier. When I picked up a wife 30 years ago, I had to swap her tires over twice a year also, and kids cars for over 2 decades...
It's peace-of-mind knowing that something is done right, and not having some random guy torque your nuts to insane ft/lb numbers is most reassuring.
Always do my own. Even when all I had was a scissor jack and a cinder block. I have major trust issues with shops. I must be bad at picking them.
The title of the post initially made me think mounting/balancing, not just wheel swapping. Which I also have done. My grandfather has a changer bolted to the floor and a static balancer. Although with these new-fangled 20" alloy wheels and TPMS, those tools have been recently gathering dust...
I'm assuming you mean winter tires that are already mounted on winter wheels so there is no need for remount/rebalance. If so, yeah, I swap those out on my 530i.
On wife's Q5, I let the local shop do the swap as I don't want to break my back.
I too thought the OP was swapping tires on wheels . Seems he / she is talking about swapping wheel / tire units .
Totally agree. Easier to just do it right, at the right time (around here = mid November).
Yes, most folks who have winter tires up here, keep them on separate rims. For the apartment dwellers, a lot of the tire shops will store your summer / winter sets in a warehouse for a fee. For the folks that have larger garage, we buy a tire rack and keep them in the corner of the garage.
I swap the winters on rims with the summer wheels every fall on the girlfriend's car. I'm not paying a shop $35 per tire to swap the rubber out twice a year.
It's way faster to do it at home than go to the tire store, sit at the tire store, interact with tire store employees, get upsold on some BS tire store service, get home to find out that the tire store messed something up, rinse, repeat.
I used to do that. The big advantage to doing it yourself is you can wait until it actually snows to do the changeover. Otherwise you'd have to get it done weeks ahead of time. The tire shops get so busy with the first snow that you'll wait days for an appointment.
But now that I live on the left hand coast, my snow tires simply rest easy in the garage. I could put them on, but I don't really need them. We hardly ever get snow, and it only lasts a day or two if we do. And I don't have to go anywhere that can't wait a couple of days.
Or if you're like I was a few years ago, you drag 4 wheels and tires up to the third floor and stick them in the closet of your 1 BR apartment.
If a functioning TPMS system is important to you, many of today's vehicles will require a trip to the shop for programming every time you swap tires/wheels with sensors anyway. Subaru is one of them that will only "remember" 4 wheels/sensors at a time. Maybe a set of snows would work if you cloned the OEM set somehow.
As it sits, I've got 3 full sets of snow tires stacked in the garage for our three cars. Two sets are on wheels. It's a pain, but sure helps when you need them.
Mine are in the basement-full sets for the xB & Cherokee, 2 rear studs for the GMC, 10 wheels/tires to wrestle in & out every winter & spring. The way winters have been lately, I've been tempted to sell them, I didn't put my Mom's winters on her Matrix last year, left them in her garage.
Have 4 mounted sets ready to swap once the weather shows its time to do it.
Have 2 new cars and 2 new sets of studded winters to go with the cars - Hakka 9s.
1st time using studs, should be interesting, been Blizzaks up to this winter.
Yes, and I mount them to the rims, and program the TPMS. Quite the hassle. But it saves wear on the tire's beads and surprise leaks. I pre-mount the next set of tires and let them sit around a while to monitor their air retention.
I don't combine the job with any other work, because I usually wait until the night before the first forecast snow, and hurry through it.
easy swap on premounted setups + getting a smaller narrower setup of the same diameter is cheaper + better. the best snow car i ever had was a 2001 jetta FWD 5 spd manual 1.8T, 200 thou safe reliable miles running 4 195-65-15 real snow tyres, summers were OE 205-55-16 i believe later i ran 225 45-17 i believe. many tyre sites show a correct downsize aka -1 or -2. i passed many struggling AWD +4 wd vehicles with all season but winter tyres + surely stopped better as well, something AWD or 4 WD does NOTHING for!!
