Hi,
I am installing a trailer hitch on two sedans. I have seen these hitches rust quite a bit, so I would like to offer some protection to the mating surface on the underside of the vehicles where the hitch bolts up.
I was thinking of some kind of sealant to slow corrosion and keep out moisture (and we have salty road winters). Found this 3M 5200 marine sealant with a little research. http://www.amazon.com/gp/aw/d/B0000AY6AC...=A297FB27E4KSS3
What do you think about that sealant? Not sure I need a full cartridge, but the next size down is 3 ounce and not sure thats enough.
Also, one of the cars has a little bit of corrosion started where the hitch will bolt up. I would like to refinish that surface before bolting up the hitch. I have an angle grinder to strip the paint, but how should I repaint it?
Thanks
Ps. Heres a picture of the hitch and how it mounts up:
Thanks
