seems to be coming from the connection itself, like it's leaking past the hose
I also think you put that on upside down. I installed the cooler on my 04 Mazda6S with the hoses on the bottom and have not had any problems with leaks. I also use Redline D4 syn.fluid with good results.quote:
Originally posted by 626LX2.0LATX1998:
I installed a tranny cooler, in series after the radiator. However the new hose I connected from the radiator(out) to the aux cooler (in) leaks tranny fluid @ the junction. I tighten the clamps as much as possible but leak still comes out. Not a lot but enough to create a stain on my condenser where the aux tranny cooler is mounted.
Hose size is 3/8", I'll post a pic in a minute.
It is physically mounted on the front, but he said it is installed "... in series after the radiator."quote:
Originally posted by TxGreaseMonkey:
It appears, to me, that the cooler is before the radiator.
