Hi you all,
This really stressed me out. I searched and read for days but still have no idea about how to deal with it. See if you guys have any idea. Thanks in advance here!
I have my 06 vw GLI with 68K mi. The CEL came on once in September for misfire in cylinder #4. I swapped out the coil on #4 and all spark plugs, cleared the code. The light stays off for two month.
But recently, I got the same code three times in the last two weeks. I could tell the slightly shaking after start up for a few times (not always), but it only lasted for about 30 seconds (which is enough to light my CEL). Then the car runs smooth and powerful, idles smooth, no abnormal sound or smell from exhaust. IMO there was no misfire at all!
The car was normally driven for short trips in low speed in the last three month
. I also have a 15 miles hwy trip every weekend. After read a lot, IMO my issue might be caused by sticking intake valve or leaky injector, since the coil and plug are almost new. But the car starts very quick, mostly takes half second only. I never experienced 2 seconds or more. Another thing I noticed is that there was a 1 second of knocking sound right after start up for a couple times (very rare). My question is if it's possible to star that quick for a engine has stuck valve or leaky injector? I was confused.
Today the code came back again. I want to start sth. cheap before throwing new parts. I took the car to do a Italian tuneup after I checked everything works fine there. Then poured a bottle of Techron in the tank. The car now idles even more smooth and quiet. Of course, the CEL won't go off until some driving cycles are done(if it fixed). I hope it will!
Honestly, I can stop caring the intermittent 30s misfire after start up. But state inspector won't! I knew Texas allows my car with 1 code of "not ready" to pass. But I guess those auto parts stores can only clear all the codes on their device, that way I will fail.
Dun know what to do now. Should I take the car to dealership? When can I get it inspected...
