Injector cleaner in Direct injection
WV
I've been told that injection cleaners do nothing for DI engines. But it seems to me that the Direct injectors have nozzles and spray patterns that need to be maintained. So wouldn't products like Sea Foam and Gumout help the direct injectors?
You'll need a cleaner with PEA as the active ingredient, so if you buy Gumout, be sure it's one of the Regane variety. This will help maintain the injectors and reduce piston deposits. As you mentioned, it can't clean the valves, but the idea is that by keeping everything else in top shape you will help to mitigate the valve deposits by keeping blow-by to a minimum. Low noack oil is also key to keeping those valves clean.
I have NEEDED to use fuel injector cleaning products in my Hyundai GDI engine (2012 Gamma GF4D 1.6L) and Hyundai specifically recommends using Chevron Techron in the owners manual. That being said the best products I have used to date have been from Royal Purple, both their Max Atomizer and Max Clean products work exceptionally well and the effects last for several thousands of miles.
Though I have been a big fan of Seafoam products they are not all that effective when it comes to fuel injector cleaning at least compared to the aforementioned Royal Purple products.
Whoever said that was slightly misinformed. Valve cleaners do nothing for valves in DI engines.
@Trav Has written about these injectors and the issues he has encountered professionally cleaning them in his injector cleaning business. IIRC he posted some pictures of DI injectors he has cleaned. The problem he has seem with quite a few of them is there is an internal "screen" for lack of a better term that fails [deteriorates] causing big problems with the injectors. No pour in cleaner is going to help with that.
I hope Trav will chime in. Added to the OP's post.....how would DI and the port injection combo benefit from a fuel injection cleaner?
As much as I dislike the purple dye in oils, I do have to admit that when it comes to fuel additives - It's hard to find products that work as great as Max Atomizer and Max Clean. But you pay a pretty penny. The only other product that provided nearly immediate (and always satisfactory) results is Star Tron Enzyme Fuel Treatment. Under $6 at Wal-Mart gives enough Star Tron for 48 gallons of fuel.
Worth checking out is some of the diesel products. Stay away from the cetane boosters. The direct injection gas engines have high pressure fuel pumps and injectors in the combustion area just like diesel engines, the lubricity of gasoline is not much better than the ultra low sulphur diesel being pumped.
Its worth a shot to consider.
Run fuel such as Chevron. Haven't had a fuel injector problem in 36 years of owning them, gas and diesels.
Well, I think you’d be better off just buying top tier fuel and running that at all times, which is suggested by manufacturers anyway. Fuel has detergents in it and when you’re talking about direct injection, you’re talking about a very high pressure spray, so it’ll clean the injectors themselves (Hopefully) but not the valves.
But spending extra money on injector cleaners or fuel additives? I wouldn’t do it.
PEA based cleaners help keep the nozzles clean but once they are clogged or partially clogged nothing in a bottle will clean them back to 100%.
Redline SI-1, Techron, some of the Gumout products will do as good a job as any Seafoam does very little if anything.
Some injectors found in a few engines eg Mazda, VW/Audi have a habit of burning the filters right out, the burnt filter particles go in the injector and in some cases damages the injector.
I usually see these at about 80-100K. I service a lot of injectors for the local Mazda dealer mostly Mazda 3 with no filter left at all just the brass ring.
Injectors cleaners clean the injectors, piston tops, combustions chambers..... how is that doing nothing?
Toptier fuel along a bottle or 2 a year of a quality FI cleaner should be considered. Just alternate among the FI cleaners.
Depending on yearly miles, a spraycan or vacuum fed IVD cleaner once or twice a year is something to consider. Both of mine GDI cars get a yearly IVD cleaning... alternating among the products available.
The kia optima owner's manual actually recommends a bottle of their fuel system cleaner every oil change. I just use redline SL1 and run it thru the tank right before an oil change. The way I look at it is since the injector is in the combustion chamber which is a very harsh enviornment a bottle every oil change will keep the proper spray pattern and reduce costly repairs, from what Ive seen those high pressure injectors arent exactly cheap. Plus the cleaner the piston crown the less chance that a hot spot develops which could cause detonation. But its your money spend it however you want.
You've been told a half truth.
Injector cleaners do clean the injectors for DI engines.
They do not however, clean the back of the intake valves, since fuel is sprayed directly into the combustion chamber.
