comments, differences? - Techron High Mileage vs Techron Concentrate Plus Complete, Fuel System Cleaners
Was going to pick up Techron on the BOGO sale, and see online a new (to me) High Mileage Fuel System Cleaner.
Any comments? Just marketing difference?
Detail:
Notoriously useless MSDSs show a change from N,N'-di-sec-butyl-p-phenylenediamine to Trade Secret for the <1% component (so, could be the same). And the main Trade Secret (may be PEA) changed from 20-25% to 10-20% (so, could be no change at 20%).
Quickly scanning the text for the HM, a few things were removed from the Complete's (longer) recommended list - but not explicitly advised-against.
PDS - High Mileage
Recommended for use in:
• Spark ignition engines with gasoline, ethanol and gasoline/ethanol blends
• Gasoline hybrid vehicles
Will not harm catalytic converters and oxygen sensors.
Not recommended for diesel engines.
Not for aviation.
PDS - Complete
• Direct injected gasoline engines (DISI)
Suitable for use in:
• Gasoline two-stroke air-cooled engines (motorcycle or chainsaw)
• Gasoline two-stroke water-cooled engines (motorcycle or marine)
• Gasoline four-stroke lawnmower, motorcycle and marine engines
since they want you to use it every 1K miles instead of 3K miles like the Complete...as well as less chance of dissolving varnish and the help for the fuel sensor (unless you need fuel stabilization) I would use Complete over High Mileage...
Bill
Appreciate the comp-chart link (didn't catch that one at the website), and thanks for the clarifying discussion.
