Information on Extended Drain
Australia
Hi Guys,
Just got my username registered here this evening on BITOG. Am a member over on Bimmerforums, as I have a 1993 BMW 320i.
Basically, I've joined here since I've spent so many, many, many hours reading hour I felt it might be time to give something back. I'm also curious about posting used oil analysis when I start getting them done.
In this post, I wanted to evaluate the potential pros and cons of extended drain intervals. My car has nearly 120K miles (193,000km) on it, and until I got it 12.5k miles (20K km) ago, it was serviced only according to the service lights, which time out at a maximum of 10K miles (16k km) on this vehicle.
The actual run it would have had on that change, with mostly highway driving was 7.5k miles (12k km), however I chickened out and changed the oil at 5k (7.5k km) to be safe with Mobil 1 0w40.
That oil did run 7.5k miles, during which the service indicator 'tripped,' and I recently switched over to Rotella until I can get the car in for some work, which substantially quietened the valvetrain, but the engine still ticks constantly when warm (thinking the chain tensioner is the root cause).
{I have a short video of this I can post if necessary}
Anyway, with the work that will proceed, that car will have another oil change. I tried a lot of searching, but haven't found a lot of used oil analysis on this age of BMW where people have bothered to stretch out the interval to around 10K. Those that have look promising, however, I'm concerned about sludge buildup over the long run. There was one post with an engine on the 15K interval for many years that looked pristine. But I'd prefer more than the odd anecdote for my own "comfort."
Looking under the oil cap, I've just managed to catch glimpses of the head, and it looks only slightly varnished. Since the VCG is leaking*, I'm hoping my shop will take some pictures for me during the process, so I can evaluate whats been going on over 21 years of 10K intervals...
*The VCG started leaking after the switch to Mobil 1, am thinking the P.O's mechanic used conventional oils. The lower chain tensioner also appears to have leaked since then...
The best thing I can do, I guess, is to start off with the oil, and take a sample halfway through the interval, and see what Blackstone have to say, and go from that. But the OCD inside of me wants confirmation first, LOL.
Have also noticed, while researching BMW Special Oils, in particular (the old, old specification), that many -50 hot weighted oils were approved for use back then. This then seemingly slipped to a 0/5w-40 (thick 40, like Rotella), before settling into the Thick-30/thin-40 ratings of today. Based on this, it seems as though almost any modern oil would meet the necessary certification needed for our older M50 engines!
Personally, I was planning either German Castrol for my DIY changes or just Mobil 1 0w40, as both (particularly the latter) seem to have very good extended drain capabilities. Even though Mobil 1 makes my poor engine tick like a watch factory... Suggestions are welcomed here!
Apologies for the long post, in no sense am I the sort of person who does stuff "briefly." I like to have all the answers to my questions, to feel comfortable that I'm making a sensible and right choice. Thanks to everyone who has suggestions to my problems. And thanks to everyone who posted in the past, all the information here has been quite useful.
A used oil analysis will tell you how a particular oil is fairing and possibly if there are excessive contaminants which could be from a variety of sources. For example, unfiltered air, cleaning sludge, a bearing that is really wearing, head or other gasket leak.
In general a used oil analysis is not cost effective, better off running a quality synthetic oil to 7K or 8K miles.
Good luck and welcome.
Hi and
What oil brand and grade were you using before the change to Mobil 1 0w-40 ?
I would run the Castrol 0w30 over the Mobil 1 0w40. for some reason Mobil 1 seems to transmit more mechanical noise. Other than that both are excellent choices. Have you considered Rotella 5w40 or Mobil 1 5w40?
Originally Posted By: virginoil
Hi and
Unfortunately, I have no clue. Its a "mystery oil" used by the previous owner's mechanic, whose abilities I am coming to doubt... I bought the car off a family member, shortly after it was serviced. The mechanic gave it the "all clear" in terms of maitenance, yet it came to me:
- Quite low on coolant (about 1-2 inches lower than "cold fill" line).
- Radiator leak from drain, and upon replacement, it seemed from another location
- Thermostat housing leak
- Suspension almost at point of needing overhaul
- VANOS noise
- Bad/Going bad fan clutch (original to car)
- OEM coolant tank from 1993 (these are known to explode, this one was clearly close. Noticed it had been leaking).
Based on this, it could have been any oil in the car... Suffice to say, I won't be going there for service LOL.
I'm presently running the Rotella 5w40 - seems to have quietened the valve train to an extent, and limited VANOS rattle. You're quite right on the 0w40 being a "noisy" oil!
Mobil 1's 5w40 used to hold the LL-98 approval, although this is no longer listed, as I suppose the present 5w40 is different to the old one. Still, similar thickness to Rotella and other LL98 oils.
If you are looking for cheap transportation, a 93 BMW isn't the first place to go. I'd say "extended drain" is penny wise.....
How long of an extended drain do you want to go?
12-16k km (7.5-10k mi) will be perfectly safe with synthetic. Especially in a warm climate like Australia with highway driving.
On a 20+ year old car and with unknown maintnance I wouldn't stretch it out to 20k or 25k km though.
Provided one actually takes care of their BMW from the start, and doesn't let it deteriorate like many often do, a BMW is a perfectly sound choice. They are just less forgiving about neglect.
The car is very fuel-efficient compared to Australian domestic vehicles, even up to a decade newer and feels "sure" and "solid."
Extended drain is somewhat penny-wise, yes.
But if it means you can actually put the money it other mechanical aspects of the vehicle, while the engine is still protected, I think is a win. Remember this isn't the US where a DIY is $50-60. Its a minimum of around $100 with a full-synthetic oil. You half your interval to meet the needs of semi-syn/dino, and it works out about the same!
(Starting from the beginning of the service cycle, by the time Inspection 1 rolls around, I would have done minimum of 3 oil changes, coming to $300, which is nearly the cost of the simplest work at the Indy!)
Maximum is the car's longest variable interval of 10k miles (16k km), with a synthetic motor oil, so anything like 12k-16k mile intervals are out of the question, at least on this engine.
On the off-topic note, I notice your username, 'camrydriver.' I was considering going done that road (Gen 3/4), then my current vehicle came up for sale from another family member, with a trusted history at a reasonable price. On the Gen 4 vehicles, I know more than around 7.5k miles is really pushing it, given the tendency to sludge inside those little engines...
