Inch lb torque wrench recommendations
Indiana
Can anyone make any suggestions for a decent 3/8" torque wrench? Less than $50 preferably.
Amazon has too many options.
I work in a calibration lab and calibrate all sorts of torque wrenches. The beam type seldom go bad, but are difficult to use in tight spaces. The "clicker" types are the easiest to use. I like the Craftsman clicker wrenches. They have a nice crisp click, generally work within tolerance, are long enough to give sufficient leverage, and are on sale at Sears quite frequently. The Harbor Freight ones are Ok, but they are generally on the short side and don't give as good leverage as others.
I have the craftsman 3/8 torque wrench click style, I couldn't be happier with it. I use it to torque lug nuts on my forte mainly, and have also used it for spark plugs. As a previous poster mentioned, they have a nice crisp click, and are extremely smooth working. I also have a 1/2 harbor freight for my Saturn lug nuts, it works nicely too but sometimes it slips? like its not catching on the gears, but I can live with that it happens so rarely.
I've had Craftsman for 30 years and they performed great - both 3/8 & 1/2 inch. I wore out a couple of 1/2 inch wrenches torquing race car wheels on, but it was heavy use to say the least. They do not come with a lifetime warranty.
Are you looking for 3/8 drive inch pound? For inch you can use 1/4" drive with a 3/8 adapter if needed.
Once you hit about 100 in. lbs you are well within the range to use a low scale 3/8" Nm or lb·ft tool
This is a consideration. Ill be getting it for adjusting my transmission bands. Space is a bit limited so the 1/4" might be a better alternative.
I was in at Sears today and took a look at their wrenches. $40 for 3/8" wasn't too bad. Only a 1 yr warranty though.. Boo.
I recently bought the made in the USA GearWrench 85051 25-250 in/lb to replace my old craftsman and I have been very pleased with it. It was nearly double your $50 limit though.
What is the exact torque spec you need? That will determine the range you need.
For 1/4" I have a little beam torque wrench that goes up to 120 in-lbs. I use it for bikes mostly.
For 3/8" I have one that goes from 50-250 in-lbs.
As far as warranty, most quality torque wrench brands I can think of only have a one year warranty. It's a precision tool that needs to be used properly.
I have had Craftsman click-style torque wrenches, and they break. I gave up on them after a barely-used one broke the ratcheting mechanism. The replacement was a redesigned head which cost about the same as a new wrench.
My go-to wrenches are the inexpensive Harbor Freight ones. I've read occasional complaints that people break bolts because they never felt the click. The 1/4" one does admittedly have a more subtle click, but it's user error when you break a bolt. You should always try a changed setting before using it on the bolt. Both to get a feel for the force required and to verify that you can detect the click.
I ended up going with a Harbor Freight model. I was unaware that HF carried an inch lb torque wrench.
I can't justify spending hundreds of dollars on a tool that I can get for a small fraction of the price at HF with a lifetime warranty. I am a shade tree mechanic so it will fit my needs just fine.
