For sure on that.I wouldn't trust a setting on an air powered impact wrench. Too many factors like air flow and compressor size. I would zip the nut/bolt down until the impact gun starts to slow down and then check the torque with a torque wrench.
Not sure about battery powered ones. I use my 20v DeWalt for tires and always use a torque wrench to torque to final spec.
There is definitely value in those settings.For sure on that.
It puzzling to me why they're even there. I've never used one not set to max beans. Like you say, by the time I factor in the pressure regulator on my air compressor, the length of air hose and all the fittings involved, my air tools are far from hitting max beans anyway.
I'm talking about what I know, which is what's used to mount tires and loosen and remove suspension bolts. I don't know if it's a wrench or a gun, and until just now, didn't know there were other types.So many different type of tools are called "impact wrench." Are we talking a pneumatic air gun or Wrench? Cordless impact? It greatly informs the answer, as well as possibly sufficient options to accomplish what you're hoping.
It sounds like you're talking about a pneumatic (air) impact a wrench, that is hooked up to a compressor, and looks like the pic I attached. If that's true, you can buy socket extensions specifically for impact wrenches that are set to a torque. Click here for an example. Click here for an example of sockets and extensions. (I am not recommending these items, I have no idea about them). I've seen them mostly at tire change locations, as they are a quick way to get the torque spec.I'm talking about what I know, which is what's used to mount tires and loosen and remove suspension bolts. I don't know if it's a wrench or a gun, and until just now, didn't know there were other types.
