I'm looking for a wheel cover for the Camry
Exactly, those alloy hub cap/lug nut covers were specific to the alloy wheel. If OP wants the steelie look with the chrome hub caps, he might have to upgrade to the BITOG favorite Crown Vic.
Funny you should mention that. Just a short while ago I discovered the lug bolt pattern for the Crown Vis is the same as the Camry. I believe the clips that hold the cap to the lug nuts may work just fine on the Camry. And @dishdude, look what I just found at Walmart, which I just ordered.
Crown Vic Caps for Camry?
I want to see some pictures of these Ford hub caps on a Toyota!
I'd like to see if they mount as well. I'll have the Walmart set around the end of the month. I chose them over the Ford item as they were without a logo. If they don't work, they can be returned.
