I'm done w/ hand pumping gear oil
Philippines
just installed a magnetic drain plug...
no more pumping! soooooooooo easy. set your air regulator to a very low psi
That's a great idea. I'm going to try it on my next transmission service. Of course, the pressure will be turned wayyyyy down. I too am tired of pumping 2 gallons of oil into a transmission by hand.
The pumps for 5 gal buckets are a very different matter, I don't mind them much. They go pretty quick. But I'm using them under a 2-post.
  • Like
Reactions: Arc
Great idea. Wish I had known that earlier this year when I did the front and back diff plus transfer case. I did the squeeze the bottle while trying not to blow the line off method.
