So one of my Monte Carlos has a persistent gremlin. I checked the code and it was an ignition module code. Since the car needed a tune up I changed the cap, rotor, plugs, and wires when I changed the ignition module out. However, when I popped the timing light on it, cause its still doggy..even for a stock smogger 305 the timing is not advancing.
so could this be the electronic spark control module or would it be a computer perhaps? I looked all over for damaged wires and its all intact. It is still throwing the same code. It runs smooth but just has NO POWER at all. I can see why almost none of these have the original ecu controlled carb and distributor on them still. They are such a pain to keep working as they get older.
