2.0L sunbird motor miss fire HELP
Ottawa
Does anyone here have a 1990 sunbird more so the TBI version of this motor that misses. Mine does and I'm very sure that it's related to the ignition. I hear that most of these motors miss. I have changed the ign module in the distributor, coil, wires, plugs, cap and rotor. It still misses. I have done a compression test and they are all around 200 psi so that can't be it. Can someone help please.
There is a gasket that sits between the Tb and the manifold, now can that go bad over time and cause missfire?
It does seem wet looking on that gasket.
It's not unheard of. Get a vacuum gauge and go through the diagnosis that's stated in a repair manual; that will help you determine if you have vacuum leaks or other weak parts in the engine like valve springs etc. that would cause a miss at idle.
