- Joined
- Nov 29, 2009
- Messages
- 8,369
So I looked at the specs for my 350 chevy boat engine. MPI, 325hp The boat holds like 120 gallons of gas and I usually keep it mostly full, but i'd reckon half of that gas has been in there a year, maybe more. The boat gets started up on the trailer atleast monthly if I can't make it to the lake, so it's not like it just sits in the garage neglected all the time. Looks like they say 87 octane is fine, but 89 is actually the recommended gas. I've always just used 87 octane. The engine does have vortec heads btw. I really can't find anything wrong that would cause my hesitation, misfiring, stumbling issue. The spark plugs look fine, the cap and rotor are okay, the fuel vent is clear, etc. I'm not sure what they run for ignition timing since it says computer controlled. Someone did mention the ignition module could cause problems under the distributor cap. To me everything seems to lead back to my old gas. Honestly, I have all kinds of engines that run 1 year old fuel regularly, never had an issue, but maybe the boat motor is under enough load for it to show up. Any ideas?
