Ignition Control Module Heat Sink Question
Toronto, Canada
The Ignition Control Module failed for a second time on my truck. First time was in 2011, so the replacement genuine GM ICM lasted fifteen years. After the first failure, I bought a spare module and left in in my glove box. This time, when the module failed, I recognised the symptoms, changed the module in the Home Depot parking lot and was on my way without a tow and not missing a day of work.
I bought a cheap ICM off Amazon to keep as a spare. I tested it and it runs my engine
https://www.amazon.ca/dp/B0C4TSLHR1
The mounting surface of this module is not flat as on the GM module, but has a recessed portion. I filled up the recess with thermal paste and bolted the module to a spare heat sink and left it in my glove box in case the ICM fails again.
I was wondering why the recess.
