2003 HVAC Control Module Repair
northern Alabama
2003 F-150 Lariat 5.4L 2WD with climate control module that only blows via defrost. Evidently, this is caused by the o-rings in the solenoids failing & needing to be replaced. Hat tip to FordTechMakuloco for this video.
Ford HVAC System Stuck on Defrost: EATC Control Head Repair
My question is on how to remove the EATC control module from the dash primarily the vacuum lines. Popping off the bezel & removing the radio is no issue along with the first connector. But I hesitated with the vacuum line assembly as I sure don't want to be breaking that. Any tips/tricks?
