Ignition Control Module Heat Sink Question
Toronto, Canada
The Ignition Control Module failed for a second time on my truck. First time was in 2011, so the replacement genuine GM ICM lasted fifteen years. After the first failure, I bought a spare module and left in in my glove box. This time, when the module failed, I recognised the symptoms, changed the module in the Home Depot parking lot and was on my way without a tow and not missing a day of work.
I bought a cheap ICM off Amazon to keep as a spare. I tested it and it runs my engine
https://www.amazon.ca/dp/B0C4TSLHR1
The mounting surface of this module is not flat as on the GM module, but has a recessed portion. I filled up the recess with thermal paste and bolted the module to a spare heat sink and left it in my glove box in case the ICM fails again.
I was wondering why the recess.
I wonder how much longer these things would last if they included high quality thermal paste and people cleaned the old one off well on the mount?
When I installed the ICM in 2011, I cleaned off really well and used quality thermal paste and got 15 years out of the ICM. The factory installed ICM only lasted five years. Google Vortec ICM to see that they are problematic. The heat sink is really not large enough and it is mounted just above the valley of the V engine and does not get cool air blowing over it. If I was going to keep the Sierra much longer. I would relocate the ICM into a cooler spot , with a larger heat sink. The Sierra is showing its age, having been in daily use, in the rust belt, for twenty years. I won't be keeping it much longer.
If the recess is more than 0.3 to 0.5mm deep, the heatsink paste is actually insulating the two parts, thermally, from each other. Heatsink paste isn't there to fill any real gaps, but to bridge the microscopic pores between to parts. A far better choice is a thermal pad that you can buy to fill larger gaps:
That is a bit of a stretch, isn't it? While I agree thermal pads should be used to bridge gaps, I don't think there is much difference in thermal conductivity betweem thermal paste and thermal pads. Thermal paste is silicone grease with Zinc Oxide to improve heat transfer. Thermal pads are silicone based (some are carbon based)
Thanks, Trav. That does seem to be the best product to fill the gap. I wasn't aware that such a product existed.
Honeywell(now Solstice) PTM7950 is even better - coming close to liquid metal(gallium amalgam used as the thermal interface in gaming PCs) and specified by Nvidia, Intel and AMD. But for this use case, it’s overkill.
the recess is usually because cheap aftermarket suppliers skip the final milling step on the backing plate to save on manufacturing. tcp71 is right that thick thermal paste actually traps heat since it only has a fraction of the thermal conductivity of aluminum. the copper shim idea is the way to go to keep that module from cooking itself.
30 years of circuit design says it isn't a stretch. yup, I'm old.
