Originally Posted By: beanoil
A Probe engine is not a high performance engine, and a 30 grade oil is all that engine needs, unless there is something wrong with it. [/quote]
While I agree a 30 weight should be fine, don't overlook the fact that the US spec engine in the Probe is a detuned Mazda KLZE, quite the powerplant for it's size...
The Mazda K-series automobile engine is a short stroke, 60° V6 24-valve with belt-driven DOHC and aluminum-alloy cylinder heads and block. Their displacements range from a tiny 1.8 L to 2.5 L. They all use a 27-degree DOHC valvetrain with directly actuated hydraulic (HLA) bucket lifters. The K-series also feature a highly-rigid, all-aluminum split-crankcase engine block design with 4 & 6 bolts for each main journal, internally balanced forged crankshaft with long, lightweight forged carbon steel connecting rods. They were designed to be as compact as possible for short-hood front-wheel drive applications. [/quote]
Yah. Mine has a Chip in it too, and some of the Ricer stuff.
Idk. Maybe ill keep it 10W-40 and do an Auto-Rx. By the end of that Rinse phase it will be winter, and Castrol SYNTEC 5W-50, which is a "thin 50" it has to be, will enter the engine at that time.
And there it will stay...
.. So maybe i DID choose an Oil!
(Oh, and regarding the Syntec. If it is ALMOST a Synthetic, but not quite, thats fine. Most of the time, id be afraid to run a Synthetic anyway, so that too suits the bill.) Why, you ask?
Three reasons:
1) Conventional advice about Synthetics and cars with around 200,000 miles.. It has th epossibility to not work as you desire. (PP Strike 1)
2) The engine came with Dino, so along the way its been used, abused, and mutilated, with certain God-knows-what done to it, maybe even some Overheats
So.. A High0Quality Oil is desired, Synthetic and Conventional terms not applying. PP Strike 2
3) AVALIABLILTY, and characteristics of Cold Flow, Hot Viscosity, and HT/HS.
Winner: Castrol "It Might be Synthetic it Might Not, Who Cares" Syntec 5W-50. AFTER ARX. (Supertech 10W-40 used during ARX. If not, Delo 400 15w40. Shoot, forgot all about Delo 400 at WM.
OK, Delo 400 15w40 OR ST 10W-40 (Ill flip a coin) for ARX, then Xastrol Syntec 5W-50 after that, first application will be in the Winter months when it comes time to start wearing the Coats and enjoying the Fall weather, before the Freezing starts.
