ID 3 cold weather testing
UncleDave
$100 Site Donor 2024
Ca.
ehhhh not so impressive.
Car "cold gates".
The tested temps are all over the place with the ID.4 at the lowest tested temperature - not comparable results at all. Let's see the Model 3 (20C), Polestar (11C), Peugeot (17C) and E-Tron (14C) do same test at (-8C).
Its on a diff test. Ill scrub for it, but they aren't comparable. Mod 3 look like 2c ?
You snipped out everything to the right of the "mi" column. Not to mention this is an entirely different spreadsheet (and measurements).
Do you have the full link for all the excel sheets so we can compare and contrast?
Pretty sure that was the whole chart.
Im pulling the sheets out of various videos - I linked to the id3 vid above.
Bjorn has posted no single chart.
The last chart came out of one of the three model 3 tests from 0-25 below.
Sometime Bjorn verbally gives the numbers in the vid and goes back later and adds the charts.
Did you watch the vid link I posted?
