I remember when cars had...
I remember when cars had Landau roofs, continental kits, and fake wirerim hubcaps and i'm glad all those things are long gone.
Hey....my first car (87 Olds 98) had 2 of those things...and a chrome "luggage rack" on the decklid.
The thing I really miss from that car are - the fiberoptic bulb indicators ( 3 little "lights" on each fender for the front end, and 2 little red dots in the center of the headliner at the rear.)
The Mercury sedans with the rear window that retracted. They had an overhang over the rear ( old version of spoiler) window so rain didn't enter while driving.
No tilt steering, no cruise control and no power locks, windows or seats.
No rear window defrost.
Rear view mirrors that didn't have a night reflective setting.
Cars had engines that were toast at 40K miles. (Chevy Vega)
Dipsticks so the owner could check their own transmission fluid.
Rear wheel drive.
Draft tubes that vented crankcase vapors directly into the atmosphere.
Front drum brakes.
Belt driven cooling fans and 3 or 4 V belts instead of one serpentine belt.
V8's with under 150HP.
When 25MPG was great mileage in an economy car.
When luxury cars got 7-8 MPG.
When cars weighed 2-3 tons.
Manual transmission where you had to push down on the shifter to go into reverse.
Always thought that was a really dumb feature.
Circle shaped air filters
Ashtrays in the door handles
Hoods that you could open from the grill openings
No air bags
Front drum brakes
Asbestos brake components
Choke levers
My dad's Rambler had these vents down about shin high above the floor on both sides of the car. Was not a good idea because water got in when it rained and he kept a sponge in the car to soak up the water.
Three speed with overdrive. The kind that over a certain speed you lifted up on the gas and it dropped it in. It could be used on second gear also, giving five speeds. Even back then people didn’t know how to use overdrive correctly.
No radio at all, just a metal plate where one would go. A/C, of course not. Some luxury cars had A/C from the back with two plastic tubes coming up behind the rear seat. I guess the A/C unit was in the trunk.
I still don't understand it as an auto transmission feature. Why don't we just use the "automatic" to do it instead of a manual overdrive button? I can understand the logic behind manual however.
Road draft tube to vent crankcase. Automotive generator and starter rebuild shops in every town.
It’s a manual three or four speed transmission with a regular clutch. They put the overdrive unit on the end of the manual trans in a special housing. There was a knob to pull out under the dash or other means to disengage overdrive, so it then behaved just like a standard trans. There are certain rules to follow in using the thing to avoid damaging it. It usually converted on American cars the 1:1 final drive output to 0.7.
So if the axle was 4:1 it made it the same as a 2.8:1,giving a substantial reduction in rpm.
