Originally Posted By: PandaBear
Originally Posted By: tmorris1
Many G routers use MIMO as well. This isn't exclusive to N.
I would recommend a router that can run open source DD-WRT software. DD-WRT beats anything out there for features and stability.
Depends on the type of MIMO, some are just "fake" MIMO not using multi-path, but usually in the router world you do get what you pay for if price difference is huge.
DD-WRT is stable and reliable for broadcom chipset, try it on some Ralink chipset router and tell me they are stable... I have one at home, and switch back to broadcom within a week (also support DD-WRT).
There are many good N router that support DD-WRT, why does it have to be either or?
Doesn't have to be either or and I never said it had to be.
In my experience if someone is having problems with a G router, they aren't automatically going to be solved by going to N. If your problems are RF path related you will probably have problems with G or N, MIMO or not. You have to solve your RF issues and a new router will not help that. The MIMO helps some, but not a lot for a stationary device. Most multi-path issues can be solved by moving the device to another position. If your router is old and on its last leg I would suggest an N router that WILL run DD-WRT reliably as I stated above. You are correct, the Broadcom is the best supported chipset by DD-WRT. I have yet to find any OEM firmware that is as stable and feature rich as DD-WRT.
