I have a prediction about future Mobil 1 formulations
  • Thread starter Thread starter i
  • Start date Start date
All the cars I've had were well made, and M1 never made any noise and actually was more quiet IMO. M1 will probably always be the #1 oil based XOM's R&D expenditures and the fact that they push that as their #1 product. It's not the best, but it's among the top 3 IMO. Plus, you can get it at many retail stores. I've seen ZERO indication that noise = wear so it's really not an issue. Just more of an annoyance.
FWIW, M1 now uses AN's instead of esters. This could have some impact on noise.
Originally posted by Patman:
People around the world truly believe Mobil 1 is the best oil out there.
What is "the best oil out there"?
Mobil 1 will always be one of the best oils out there bc it's XOM's flagship product and they dump a lot of $ into R&D. Different versions over time have varied in quality. Mobil 1 SuperSyn is better then Trisynthetic IMO.
I have no doubt that some of the loyalty among the average drivers is due to their advertising, reputation, and time in the market. I work in parts at a Chevy-Buick dealer and am continually amazed at the number of people who pay our ridiculous price for M1. We use Mobil 10w30 conventional in our bulk pumps and they are happy to deliver boxed goods to us when they come to fill the tanks. Our cost on both Delvac (GM's preferred oil for Duramax) and M1 is higher than we could get from Wal*mart,
I'll continue to run it in my wife's '01 Monte Carlo 3.4 because I let the oil change monitor do it's thing and like the extra protection. It almost always goes 7500 miles (the max on this car) before turning on. I stopped using it in my Hyundai Accent 1.5 because in cold weather on startup I almost always had 2-3 valve adjusters that bled down overnight. I'm now using the Trop-Arctic 10W30 since I never could bring myself to go over 5K on that car.
Incidently, the 3.1/3.4 noise debate is way overblown, we don't even stock the special 3.1 pistons anymore and only installed a couple sets when they first became available. I know at least one set ('01 Buick Century) was installed not for piston slap but because the owner found the TSB online and demanded that GM replace his pistons. I think the noisey ones were all built before that, and if you have one it's probably a bigger deal, but we don't see it that much. My wife's 3.4 has more belt and injector noise than anything. I think engines in general are noisier now due to all the friction reduction measures being incorporated and I'm not convinced M1 has any effect on that aspect.
BTW, when I worked here in the '80s all we ever put it any car anytime of year was 20W20. I was aghast when I found this out, but we had lots of folks that put well over 100K on Chevettes, etc. commuting to jobs in St. Louis and no complaints that could be blamed on oil. Kinda makes you wonder why we all need to obsess about oil, not that I'm going to stop.
You're absolutely right. Engines done't die from wearing out from poor oil, they die from dirt and deposits.
Oil analysis doesn't show the whole picture either, and the fact that some people cry over 5-10ppm of a particular wear metal is really borderline OCD. Rather than have the oil checked, they should have their heads analyzed.
Wouldn't surprise me either if some of the people that post compliants about it are closet Amsoil dealers.
I don't doubt many of the noise compliants with M1, I've just never experienced it personally.
I have a prediction about Mobil 1, too. ExxonMobile will continue milking the cash cow with sub-specialty formulations to give BITOGers more grist to grind in their unlimited quest to satisfy their infinite angst over what oil to use in their ratted out twenty year-old Ford Crown Vics.
Originally posted by ekpolk:
You've posted about 100 times about your dislike of Mobil-1. Now, would you care to share with us why you feel this way?
In one of my posts, which you probably missed, I wrote how my suspicions were raised when, one day several years ago... I'm not sure now, maybe seven or so years ago, I changed out the old Mobil 1 (at 3,000mi), put in new Mobil 1, and for the first time, my engine turned into a clatterbox. I started wondering then if they had changed the formulation. I only left it in for about a thousand miles, and changed it out for fresh Mobil 1, and the engine was still a clatterbox. I decided it must be my imagination and kept using it. The engine had about 100k on it at that time; the car was a Saab 900 8-valve 2.0 liter, one of the most bulletproof engines of all time. By 180,000 miles, the compression was way down and that should NOT have happened. I personally yanked head off and had a machine shop clean it up (I was assuming it was a valve problem) but the compression didn't come up, so I got rid of the car. So Mobil 1 let the rings or cylinder walls on that motor wear out. It was NOT my first 900, it was my 4th, and two of the previous engines I had taken past 200,000 miles with no appreciable decline in compression. Then I got into volvos (RWD 2.3 liter motors), and the same thing started happening -- I'd swap them to Mobil 1 and they'd turn into clatterboxes.
My very first post on this board, and the reason I joined, was to ask why, after a good hard 100+mph run, the Mobil 1 in my Volvo, my engine would be INCREDIBLY loud, until an afternight cool off. Most folks on this board said it shouldn't be happening, but it was.
Then, through this board, I discovered GC, put it in my old Volvo, and you know what happened? No more clatterbox, engine still quiet all the time, even after extended 100+mph runs.
Do I KNOW that something is wrong with Mobil 1? No, not for sure. But I'm putting the alert out there, so that folks who know better than me have a heads up and can keep an eye on what's going on. Maybe there is something wrong at Mobil corp, maybe there isn't. But if there is, the problem is only going to fixed if they know we're onto them.
I just bought a new Scion tC. Am I going to run M1 in it? At this point, heck no! Not until some folks can conclusively show me I'm way off base. Right now, all we seem to have is opinions and conjecture. Better safe than sorry.
OMG
"Amsoil and Castrol all use Lubrizol as an additive supplier. That could be why we see different wear metal results."
Buster they do but they also by from the other guys too you can tell by the "chemistry" on VOA.
bruce
i, for every one of your complaints about it, their are hundreds that have had success with it. Corvette owners never run into problems using M1 and I know several guys that run them hard. It could have been a defective engine or wrong viscosity choice. It could have also been the oil, but I personally havn't seen any oil really cause an engine failure since I've been on this site. All oils do a nice job as long as they meet the specs called for.
Not wrong viscosity choice. It could have been a defective engine, I agree. Other Saab motors had metalugical problems (with the heads), so they certainly weren't a perfect company. I am just an isolated data point. Nevertheless, there are other choices out there, and I choose them instead now.
i member #5604 wrote:
"Do I KNOW that something is wrong with Mobil1? No, not for sure. But I'm putting the alert out there, so that folks who know better than me have a heads up and can keep an eye on what's going on. Maybe there is something wrong at Mobil corp, maybe there isn't."
There is nothing wrong with Mobil 1 and Fram makes a lovely filter.
yea, when Walmart has mobil 1 stacked up next to the orange filters, you have to wonder....
Yeah, and when Castrol Syntec is stocked next to Pennzoil Platinum which is stocked next to Mobil 1 which is stocked next to Fram Filters...makes you wonder.
It's a conspiracy!
I guess the safest thing to do is go with the oil fartherest away from Mobil 1. That would be Wesson...
