- Joined
- Sep 28, 2002
- Messages
- 39,799
My only reference to the 51749 was to compare its size and cost to the average user. If you wanted a bypass filter that could handle your full flow ..I think a Luberfiner 750 would be in order.
Anyway...
What I do know is that having two (2) 51641 bypass filters should give me substantially more surface filtering area then the 51749.. So, both filters should last a substantial time before needing replacing (ESPECIALLY since I will still have the stock, full-flow filter).
They will last twice as long as one 51641 in your originally proposed installation, at least at their highest potential for effectiveness.
Is it economically intelligent for someone to purchase the dual base and run two 51641s instead of a single base and a single 51749? I'm willing to bet the answer to that is a simple, **** No. It may be. Neither of us knows what kind of longevity either system will have in your application. I would think that the most effective manner to use this would be to swap one bypass filter out at a proposed midpoint in the OCI so that you would have approximately the same holding capacity at all time. You would have a 1/2 saturated filter when the other was being swapped out. It will take a couple of UOAs at 10k and 20k (or at 15k just to see if soot levels are on the incline) to see if it's doing the job that you intend. The costs will be slightly out of phase with your cost schedule. You may find that your oil and filter intervals are independant of each other. Your oil may have too much fuel or have lost too much of its visc ..yet soot/insolubles may still be low. You probably won't have to swap out your full flow at midpoint.
Now you see why tp is so popular. It's a quart of oil (at most) and $0.50 for the roll.
I don't do diesel ..or at least I haven't in about 28 years. I think you should post this in the diesel forum to get those opinions. My main thing is exploring the hardware.
I've been there and at least thought of doing that at one time or another.
Anyway...
