I know that I cannot be the first person to think of this, so I have to ask.. Why won't it work? I'm assuming that I am missing something here, otherwise everyone would be jumping all over this. So, here is what I have researched.. My plan.. Should it work, or is this bound to fail?
What I am trying to do is build a bypass filter system out of commonly avaiable parts for less then 1/2 the price of the expensive, after-market type brands.. Now, I have nothing against Amsoil.. Infact, I'm trying to duplicate THEIR system.. I just want to see if it can be done CHEAPER.
I want to take a block-off adapter from my oil filter on an 01 Dodge Cummins. I want to run this block off over to a remote, 2 filter system. 1 filter will be my full flow, the other filter will be my bypass. As you can see, it is identical to the Amsoil system.. But, where I want to differ is in A: filter base, and B: Filters.
It is my #1 goal to be able to purchase my filters from almost any local autoparts store, and be able to purchase them for much less then the Amsoil system.
I am planning on using a dual remote system that has standard 3/4-16 thread base. For the first filter, I want to use WIX #51773. This filter has the correct 3/4 thread, is 6.91 inches tall, and has a similar bypass setting to Amsoils at 8-11 psi. It has a burst rating of 225, which is very similar to the SDF-26 from Amsoil, I am told. The problem I am fighting is this: the filter is only rated to flow at 7-9 GPM. Is this a problem? I have not been able to find ANY information on the Amsoil flow rates... I am assuming that if Amsoil's SDF-26 flows at a similar rate, then it should work.. ON A SIDE NOTE: Irony at its best, I am also considering the SDF-26 as a filter option if I cannot use the Wix.. I have researched several filters in this size, including PH977a, Wix 51773, and it appears to me that these are the same as the Amsoil SDF-26.. I just need to make sure that the Wix filter meets the same (or extremely similar) ratings as the Amsoil filter... If Amsoil is willing to put a filter in their Dual remote system that has a bypass of 7-9 psi, I have to assume that this will not harm my large Diesel engine.
For the bypass filter, I am considering the Wix 51641. This filter has a 7-9 GPM flow, 3/4-16 threads, and a 345psi burst. I have not been able to find any information on the Amsoil BE-100 bypass filter, so I need to know if these ratings are similar? What grabbed my attention was this filter is a 3/4-16 threaded bypass, where it seems to be dang near impossible to find a 3/4-16 true bypass filter. I spoke with someone from Wix who told me that this filter will take 10% of the oil and filter it through, while the rest of the oil will be sent back to the engine. The other problem I have with this bypass filter is that it is only rated to 12 micron.. Obviously, I would like a lower micron count, but in the sake of saving several hundred dollars, I will sacrifice micron rating for cost.
The cost?
So far:
Dual Remote Filter Plate: 9.99
Wix 51773 Full Flow: $10.50
Wix 51641 Bypass: $28.72
I still need to purchase the block off adapter from Amsoil (the part that sends oil from the stock filer location over to my dual remote) and I plan on purchasing some high quality lines for the oil. I imagine it will bump my price up to around $100-$150 for the enire system, so the INITIAL costs not going to be as much as I hoped. However, my continued costs for filter replacement should be considerably less... (lets not get into an arguement of drain interval and filter replacement... I know what Amsoil claims their filters are good too, and I WILL not run filters that long. I have my drain/filter intervals decided, no matter what a company states, so no matter if I am running Amsoil filters or these Wix filters: my intervals will remain the same).
The biggest concern I have his GPM flow, and making sure that I do not starve the engine of oil. Does anyone know what the SDF-26 oil filter and BE-100 bypass filters from Amsoil are rated at as far as GPM?? That would really put my mind at ease..
Are there any other ideas/concerns as to why this system would not work? Anything that I am forgetting?
Would I be better off leaving the stock oil filter in place and tapping into the small access hole on top of the adapter plate on my 01 Cummins, and then running a return line to the valve cover? Or does the adapter that removes the stock oil filter and takes all the oil over to my dual remote system seem alright?
What could go WRONG?
The cost?
So far:
