md_lucky_13
Just go to NAPA and ask for "Transmission Return Line Hose". It will have SAE J1019 on it. It's good for 400psi and SURELY can withstand 212F. It's a Gates product.
Medium Pressure Hydraulic Hose
(G1) C1T 1 Wire Braid Hose
Fleet Medium Pressure Hose
For medium pressure hydraulic oil lines. Approved for Marine Applications. (SAEJ1942)
• Meets DIN 20022 1SN – 63 to 250 bar working pressure.
• Meets or exceeds SAE 100R1AT.
• 925 to 3,625 psi working pressures.
• Synthetic elastomer tube with NBR cover.
• One high tensile steel wire braid.
• Sizes 3/16" through 11/4" I.D.
• No skiving required.
• Temperature rating -40°F to 212°F.
Uses Gates Power Crimp® and MegaCrimp™ Couplings and field attachable couplings.
C5C Hose
For medium pressure hydraulic petroleum-base oil lines in many applications.
• Meets or exceeds SAE 100R5, SAE J1402 Type AII and DOT FMVSS 106-74 Type AII.
• 350 to 3,000 psi working pressure.
• One high tensile carbon steel wire braid over polyester braid.
• Nitrile tube.
• Textile braid cover.
• Sizes 3/16" through 23/8" I.D.
• Temperature range -40°F to 212°F (hydraulics). -40°F to 300°F for Fleet Applications.
Uses C5 type field attachable and permanent (thru -12 size) couplings.
C5D Hose
For petroleum base or phosphate ester fluids. Recommended for diesel engine flexlines.
• Meets or exceeds SAE J1402 Type AII, SAE J1019 and DOT FMVSS 106-74 Type AII.
• 400 to 1,500 psi working pressure.
• One high tensile steel wire braid over polyester braid.
• CPE tube.
• Sizes 3/16" through 7/8" I.D.
• Green braided textile covers for easy identification.
• Temperature range –40°C to +149°C (–40°F to +300°F).
Uses C5 style field attachable couplings.
C5E Hose
For air brake hose, power steering, fuel filter, engine and transmission coolant lines and hot +149°C (+300°F) lube lines. Recommended for diesel engine flexlines.
• Meets DOT FMVSS 106-74 Type AI and SAE J1019 hot oil circulation test.
• 300 to 1,500 psi working pressure.
• One braid high tensile carbon steel wire over polyester braid.
• Textile braid impregnated with rubber on black cover.
• Nitrile tube.
• Sizes 3/16" through 11/8" I.D.
Uses C5E type field attachable or permanent couplings.
Gates
The stuff is cheap.
