Originally Posted By: VNTS
Originally Posted By: mechtech2
VNTS -
Don't you think a dedicated manual transmission fluid is best? C'mon now... is motor oil better than real transmission fluid biased for synchro action, with anti wear and extreme pressure agents also?
CHrysler switched to 10w30 motor oil in the factory fill for transaxles in 1988, thru 1987 they filled with ATF.
Look up Ed Peters, he stated that they switch to the motor oil to improve durability of the transaxles and the only reason they originally used ATF was for cold wether shifting and one less fluid at the factory, BTW he was the head reliability engineer at Chrysler at that time. He also built a lot of SCCA Neon motors which dominated their class back in the day.
http://www.thedodgegarage.com/friends_ed_peters.html
Oh per the MTF, I use the MTF Amsoil has once they came out with it, but prior to that, I used the 0w30 engine oil in my Getrag gear sets in my Shelbys.
Yes,10-30 should be better for wear than thin ATF.
And like I said, a modern dedicated manual transmission fluid is better than both.Your engineer friend was constrained by costs, and hampered by not having access to fluids that weren't invented yet.
