Originally Posted By: slybunda
so does that mean higher hths is needed for badly designed engines that have poor manufacturing resulting in loose bearing clearances and need the higher hths thicker oil to take up the slack?
No, not really.
Design is an iterative process...you pick a design point (temperture and viscosity, having known the load), then design the bearing around a bunch of knowns...analyse (mathematically), and find out that the heat rise is more or less than you calculated, then iterate down to a design...then test.
Diameter, Clearance and Length, are your mechanical variables that you can change.
So to say that a particular design is "bad" when you don't know what the designer was designing for/around is incorrect.
Engines are total packages, and piston friction is a big part of overall power losses...thus the strange skirt shapes that we see. Honda in some of their papers appear to be focussing on viscosity to reduce piston skirt friction, and are having to make blocks stiffer, and bearings bigger and tighter to provide sufficient MOFT on these thinner oils (and more bearing friction/higher oil exit temperatures)...they are scraping the last few hundreths of an MPG out of engine friction. Now they are on the teeter totter of trading piston and bearing friction, they will have to look more at additives, and start to abandon hydrodynamics as the basic protection mechanism.
