Metals are high based on what? Your feelings that you don’t like to see these numbers? Here’s another Ram, with a little over half the OP’s mileage below. I would have used Blackstone’s universal averages but unfortunately they rarely tell you the mileage they interpret as the average for that number. About the only thing that appears any worse at all is aluminum (~2ppm/1k mi vs 0.5ppm/1k in below sample), and if SuperCar is like some of the other HPLs, it may have some in virgin form as well, so you would have to subtract that from the UOA to get a true result for OP’s sample.
Other than that, OP’s iron is about 4.67ppm/1k mi vs. this sample’s 7ppm/1k; OP’s copper is lower with 68% longer mileage (I know copper can trend with time in service rather than just miles, but I’m not going to guess on that)… I’d say that based on data, the oil did at least as well as a small comparison of other similar engines like his. Considering that fuel, soot, oxidation, viscosity, and TBN are all acceptable the oil was still serviceable. But I do agree the 30 grade isn’t going to hurt.
