Japanese
$50 site donor 2026
The CCS, I'm sorry.What spec are they showing on the PDS?
I can answer this one at least. He wants higher viscosity. HTHS tops out at 3.6 on that line. Good for a racing oil, but if you wanted a racing oil, then just buy their racing oil. The Euro oils top out at 4. He is looking for 4.2 minimum HTHS. That's basically where wear hits the asymptote of little to no wear occurring per Leslie Rudnick's writings. He likes the PCMO line due to the value and it checking all the boxes he's looking for.Why not just use the HPL no-VII multi-grade? Then you know the W rating of the oil.
Is this car used on the track? ... I don't recall if that was mentioned. The HPL 10W-40 has a HTHS of 4.06 cP, that's some decent dynamic viscosity. HPL 10W-50 has a HTHS of 5.07 cP if someone want's to go wild, lol. 10W would in the best case scenario would be good for -25C (-13 F). Like mentioned earlier, most vehicle manufacturers that show a viscosity vs ambient temps chart will typically be more conservative than J300 specs. That's because each engine behaves differently to cold starts and not all engines may be able to safely cold start at the minimum W grade temps shown in J300. That's why the Yamaha OM shows much more conservative minimum temps for the viscosities listed.I can answer this one at least. He wants higher viscosity. HTHS tops out at 3.6 on that line. Good for a racing oil, but if you wanted a racing oil, then just buy their racing oil. The Euro oils top out at 4. He is looking for 4.2 minimum HTHS. That's basically where wear hits the asymptote of little to no wear occurring per Leslie Rudnick's writings. He likes the PCMO line due to the value and it checking all the boxes he's looking for.
No it is a commuter car.Is this car used on the track?
He has expressed interest in the 50 grade HPL offerings...HPL 10W-50 has a HTHS of 5.07 cP if someone want's to go wild
Right. That's why the MRV is the real startability limit where the OIL is the limit. CCS is the startability when the starter and battery are the limit.In the paper linked in post 254, they talk about how newer engines with fuel injection start much easier in cold weather. Re: part in bold ... the limit of the oil is the pumpability viscosity in SAE J300. If an engine happens to start when the pumpability viscosity is beyond the W rating, then engine damage could occur. If the engine starts, the oil better be pumpable, otherwise oil starvation will happen. The SAE paper in post 254 talks about that.
I mean that viscosity is a two way street. I higher VI doesn't just thicken less when cold, it thins less when hot.It's a 40 grade, so when at 100C and 150C the kinematic viscosity and HTHS viscosity are thicker than any viscosity less than a 40 grade. Don't know what you mean in the bold part in your post.![]()
My calculations/estimations suggest the monograde would test as a 15w by MRV, but likely a 20w or 25w by CCS.Is this car used on the track? ... I don't recall if that was mentioned. The HPL 10W-40 has a HTHS of 4.06 cP, that's some decent dynamic viscosity. HPL 10W-50 has a HTHS of 5.07 cP if someone want's to go wild, lol. 10W would in the best case scenario would be good for -25C (-13 F). Like mentioned earlier, most vehicle manufacturers that show a viscosity vs ambient temps chart will typically be more conservative than J300 specs. That's because each engine behaves differently to cold starts and not all engines may be able to safely cold start at the minimum W grade temps shown in J300. That's why the Yamaha OM shows much more conservative minimum temps for the viscosities listed.
Here's what I'm talking about - I put the J300 W section in there and annotated the differences. Yamaha won't push the engine to take the minimum J300 W grade temps ... maybe it mostly due to starter and battery capability, but could also be due to some lubrication concerns.
HPL doesn't show any CCS or MRV test data for their straight SAE 30 and SAE 40 grades. It would certainly be interesting to see where they would test at. Could be their straight 40 grade comes in equivalent to a 15W-40, or it could be a 20W-40 ... wouldn't know without actual test data. Even if it was basically a 20W-40 it would theoretical be good for -15C (5F) in the best case scenario.
Good summary. Dang, I'll just delegate to you.I can answer this one at least. He wants higher viscosity. HTHS tops out at 3.6 on that line. Good for a racing oil, but if you wanted a racing oil, then just buy their racing oil. The Euro oils top out at 4. He is looking for 4.2 minimum HTHS. That's basically where wear hits the asymptote of little to no wear occurring per Leslie Rudnick's writings. He likes the PCMO line due to the value and it checking all the boxes he's looking for.
Did you see Table 2 in the SAE 922287 paper linked previously? Kind of interesting about the 3 Zones involved in cold starts and the suggested changes to J300 in Table 2 in terms of startability and pumpability max dynamic viscosity. Apparently that never happened.But in the case of HPL oils, the MRV is far, far below J300 limit-- sometimes only 20% of the allowed limit. So even the "thick" HPL oils have superb pumpability at very cold temperatures, far better than the 15w or 20w (or the lack of a "w" at all!) would suggest.
Yes, things could go much different as temperatures get lower. That's why it would be interesting to actually see the CCS and MRV dynamic viscosity of the SAE 30 and 40. That's the only real way to know how they behave without guessing/estimating. I bet HPL has ran the tests and have the numbers ... seems they would be curious themselves.Which is why so far the monograde SAE 40 has been much ado about nothing in terms of cold starting. Now a lot can change in 15 degrees and the effortless starts at 28F (this morning) don't mean 15F is cake walk. But it does mean that 20F is likely to be manageable and for a mostly garaged vehicle that is rarely to never starting with oil temps of 15F, the monograde becomes surprisingly viable.
Yeah, 28F isn't too alarming. Even if it was equivalent to a 25W-40 it would theoretically be good down to -10C (14F).I've been advocating for the SAE 40's cold viability based on the 15w-40 and a bit of faith in specs and calculations. But now that I've had it in and started at 28F or so more than once, I'm feeling like this whole exercise is far less risky than I initially suspected.
Oil pressure can't always be a trusted indication that all parts requirement adequate lubrication are getting it "instantly". With cold starts and thick oil, the thing I'd be concerned about most isn't the areas of the oiling system that are force fed oil under pressure, but any parts that depend on splash lubrication, like cam-chains or piston skirts/cylinder walls (if no oil squirters) for instance.Even at 28F, the oil pressure is INSTANT. That's the payoff of the very low MRV relative to grade of these HPL PCEO formulations. GTL bases ftw.
I've been taking notes.Good summary. Dang, I'll just delegate to you.
Wants high HTHS
Wants no VII
Want PCEO for cost
Thinks it might have more AN at lower VI
Thinks the cold crankability is actually OK![]()
Yeah, lower VI means its viscosity vs temperature curve is steeper and viscosity change per degree is higher. But if the HTHS is still there in the high shear areas as long as the oil temperature can be kept down to a reasonable level. And the full shear viscosity will be better because there is no VII, and engines running near redline on the track could benefit from that vs say a Wx-40 or xW-50 with lots of VII. A straight 40 would still provide more MOFT protection than any xW-20 or wW-30 grade.I mean that viscosity is a two way street. I higher VI doesn't just thicken less when cold, it thins less when hot.
The monograde gets around this by simply shifting the entire curve upward in viscosity. But it shifts the bottom end up much more than the top end.
That's why I think it likely a poor choice for racing, there's a pretty significant pump work penalty on this oil compared to a 0w-40 or likely even a 5w-50. I'm guessing most vehicles would show a 5hp or more detriment on the monograde.
An in-field study like was done for J300 in the winters of 1980-1981 and 1981-1982.So who in MN or ND is signing up to be the next monograde tester? Anyone? Buehler?![]()
K20C4 has a fixed oil pump. I have no idea what the oil pressure is because Honda only uses a switch and not a sending unit. I’m working on a way to remedy that, but I’m having to learn some arduino first. More to come on that front.What has Cold Start High Idle/ warm Idle Oil PSI been since you made the switch? Is it a variable oil pump in our accord?
I think the detriment of higher viscosity is higher on the torque than is on the HP or at least is felt more easily, especially on cars with manual, and especially in the city. From my experience.I'm guessing most vehicles would show a 5hp or more detriment on the monograde.
When I said qualifying I meant lap times.This isn't racing so no qualifying.
You really think that you can detect a somewhat higher viscosity oil at operating temperature?I think the detriment of higher viscosity is higher on the torque than is on the HP or at least is felt more easily, especially on cars with manual, and especially in the city. From my experience.
