My quest to find how long I can run this oil continues. Looks decent save for the Silicon that keeps climbing.
Last UOA at 6k miles I took the intake apart and checked everything from filter to throttle body, all good. After seeing this latest silicon number I ordered a K&N disposable filter (didn't know they made these!) as the price was right. I took the cover off of the airbox where the filter should seal with the felt strip and moved it around to see if it could potentially create a gap. Sure enough, in 4 directions if it moves far enough it created a decent gap. I did that with the new K&N and could not get a gap in any direction I moved it. Side-by-side the Purolator filter has a noticeably narrower felt seal and it is quit hard, not much give to seal correctly. Think I found my silicon issue here, though time will tell! Needless to say, no more Purolator air filters in this house!!
All that being said, opinions on what I should do next? Change to get that silicon out and keep monitoring? Keep running it? Let me know your thoughts.
Thanks!
Thanks!
