Panda87
Your last paragraph was my thinking on this. Thanks for the input. I’ll simply sample again at 170,000mi and again at 175,000 just to try to get a trend on this.Unlikely. Even if it did, most of the oil would still go through the filter media as the bypass spring only opens enough to keep the pressure differential in check. I doubt it's opening at all though as it's a rare event.
The HV pump will still increase pressure. More volume against the same clearance means pressure will increase some if still below bypass spring pressure. It just still bypasses at the same 60 psi.
