- Joined
- Nov 14, 2023
- Messages
- 7
I have a new to me 2012 f150 longwheel base.
After performing tsb to grease slip yoke and slide center bearing rearward, I have a much more anoying shudder anytime I accelerate from a stop.
Seeing as I was very carefully to keep everything indexed, I'm thinking it could be due to me messing with the center bearing.
What is the proper way to install these things? There Is a lot of adjustment in all directions before you bolt it down. Also when I go to torque things down everything shifts, is there a trick to these things?
