Good evening!
I have never adjusted valves before so here goes. This is on a 2020 Yamaha SMAX 155cc 4 cycle scooter.
I have identified the exhaust and intake valves and can easily turn the engine with a socket.
My big issue is being 100% I am adjusting these on the top of the compression stroke at TDC.
I inserted a clean wooden dowel and cranked until the piston came all the way to top. Am I right in assuming that I have found the compression stroke if the rocker arms have a little play in them? And if I am on the top stroke of exhaust, they are tight and don't wiggle much at all?
ETA: Yamaha has no timing marks visible unless you remove the radiator and the water pump. That's crazy, so I am finding another way to determine.
