It is as I found out a well known problem on the early Kohler Courage engines. Mine is a 2007 which I believe they started using these engines in 2006 or 2007 maybe? The top cover bolts either weren't torqued down enough from the factory or no lock-tite was used to keep them from vibrating loose. I had a bad oil leak from the top cover gasket and when I removed the flywheel to replace the gasket found six of the bolts on the head side finger loose or even sticking up a bit. A few You-Tube videos later and I learned a lot about the problem. One bolt near the coil had been sheared off by the flywheel at some point and that is what caused the crack. The flywheel hitting those bolts!
