Well, IF i have to take my older car and pull the Head off and put a new Head Gasket on it, id like to know if there are any Tips! I used to take it to a cut-rate mechanic and ive had heads changed for as little as $200. They ALWAYS put RTV Silicone (Ultra Black) OR used Gasketmaker in lieu OF a gasket (I think they put it ON a gasket) and followed it up with some "Block Sealer" and .. well once it worked OK and two times it didnt on various cars. I have a car i like more now, and im going to pressure-test the Cooling system to see what the rust-colored Oil was about. if it "Fails" the pressure test, i think no more sealers (Blue Devil, etc., its never went on this car, other cars it has) a Head and Gasket job is in order.
Now, in reality a Head job should cost closer to $1200 than "$300 or $400" to be DONE CORRECTLY, right? And ideally, the heads are pressure-tested too? (We used to just put a "New Head" back on the old block with new gasket if we could find a used head from junkyard car. If i had to get a new head for my car, rebuilt and guaranteed it would likely cost about $2000. Not against it and no we dont want to "Open the block up" but maybe do the cam/crankshaft (camshaft and crankshaft) if it shows wear, and of course clean up what we see, then run Oil for 30 minutes then change to specified grade, no more cleaners and stuff.
However, in shopping for a shop since i can change my own Oil and thats about it, getting to wrenchin' a Head Job is WAY BEYOND my tools, time, and everything.. what do I look for in selecting a shop?
Oh, and this car has been sitting so time is of no importance, just to get it right, assume its just a Head Gasket leak, if Pressure Test confirms, i think it may, to be honest, idk but when/if that result comes in.
FTR: My last car "Dropped a Valve" a month and a half after the $200 Head Gasket job was done, and the Cylinder walls were "Washed" and rusty and a globule of K&W Block Seal was in there too. Trying to NEVER HAVE THIS HAPPEN AGAIN Ill PAY $$$$ for a HG job done RIGHT, but what do i look for? OR any tips, so i am familiar with what they will actually be DOING when they TAKE a few days to DO it?
