API SC is more of a back spec for engines from the late 60s, I believe when the API S-rating came about SD was the spec for current cars and they created the SA-SC speciation's for ranges of older cars though, for the model years SB and SC are specified the active specification at the time for gasoline engines was API MS (most-severe)First picture:
API SC ended in 1967.
Caterham would not like low VI 0W16.Caterham anywhere?
It's not that a stock engine in a normally vehicle should follow those guidelines, it was a rule of thumb for minimum pressure needed in a SBC when you've got a hot sump in your racecar.So i don't think the 10 psi per 1000 rpms applies to my old relic
10W30 in my 1996 Chevy C1500 4.3
60 lbs idling cold.
40 lbs idling hot.
50 lbs hot at 2000 rpms.
First picture:
Last picture:
QR Code was invented in 1994. Curious if the Belgium 10W is still on the market and if that company makes the GC now?
what is the natural "hot rating" range of a 20W without vii? Can you formulate one to be a 40 or 50 grade for example? What would be the easiest or least expensive natural hot grade (no vm) to formulate?
Turbochargers don't generally need a ton of film strength. They just get hot.Does that 10 PSI per 1,000 RPM rule include turbos?
That help?
Good to see you back, Dr. Haas!I have been away from the site for years. It seems now I have some time on my hands as I am close to retirement.
Anyway, it is simple: The rule is that you need 10 PSI for every 1,000 RPM of engine speed. I generally like to keep it as 8 - 12 PSI.
In a thread somebody was asking what grade to use. He stated that he mostly drove “normally” but on occasion was on the track. He got all sorts of advise but the correct response. He needs two oils, one for each application. He needs to use whatever oil gives him the appropriate PSI for his different applications. It’s that simple.
FYI, my Ferrari 812 Superfast normally runs at 35-45 PSI at idle (650 RPM) at normal operating temperature while driving around town, my only application. The oil temp has never been above 170F so far. The oil is a 40 grade but surely I can use a 20 grade safely. The maximum oil pressure is limited to 80 PSI at 9,500 RPM because of the pop off pressure valve. So Ferrari thinks that 80 PSI is enough for 9,500 RPM. They do caution that the engine must be fully warmed up before running up the RPM - Why? They do not want the oil to be too thick with higher RPM.
AEHaas
^^^ Per the J300 table, "20W" can be 5.6 cSt KV or higher, but it must also meet the 2 low temp requirements. There is no defined max KV in the J300 table.
Probably because the KV info on the "W" oils helps define the behavior of the oil better. But I agree, seems the low temperature spec requirements are most important.^^^ I guess the part that confuses me is if the W rating is all about ccs and mrv, then why have the Minimum Kinematic cSt column to begin with?
Why can't they just get rid of it and let it roam free if it meets the other 2 major specs?
Because those specs are at different temperatures, which then helps define the behavior of the oil better.
Here's an article on the history of SAE J300.
http://viewer.zmags.com/publication/591c23e6#/591c23e6/30
