How old is too old for brake fluid?
eastern NewMexico
I tried searching and all I found was posts about open brake fluid and far older bottles (10 year old) brake fluid.
I've got sealed plastic bottles of Prestone dot4 brake fluid from i was going to gueas was 2020 at the latest. Then upon closer examination I believe I found a date code indicating the 159th day of 2022 so not terribly old.
I'm in New Mexico so relative humidity is usually only above 80% maybe a dozen days a year and is usually between 15 and 35% most of the summer and is nose bleed inducing during the winter.
Sealed, I'd say its still good. Opened and capped, I'd recycle it.
So if I open a bottle to use in a brake or clutch system, I try to flush that system and use the majority, because I know I won't use the rest of the bottle in a reasonable amount of time (like a few weeks).
If they're sealed I wouldn't think twice about using them myself. I've begun flushing brake systems more routinely, but we have lots of old cars in the family running 10-20 year old fluid that sure seem to stop fine... I think everyone flushing the fluid every 3 years is a bit overkill. I do have one of those brake fluid testers, not sure how much I trust it as I've never seen it say any actually has to much water in it.
If they're sealed I wouldn't think twice about using them myself. I've begun flushing brake systems more routinely, but we have lots of old cars in the family running 10-20 you fluid that sure seem to stop fine... I think everyone flushing the fluid every 3 years is a bit overkill. I do have one of those brake fluid testers, not sure how much I trust it as I've never seen it say any actually has to much water in it.
Yes the 2 I found were sealed.
Oh I take my unsealed brake fluid bottles that I know im not going to use into work and they'll get used within a few months at the most.
I enjoy the posts you have about the equipment maintenance there!
Nothing really that interesting any more now that ive been running things for a while and I think ive found the worst of the neglected equipment.
Ive got a cummins 6.7 oil filter that will have like 3 oil changes on it.
I'm expecting to find a whole lot of nothing in that oil filter.
I'm reminded of what I once heard a European automotive engineer say:
"The difference between European drivers and American drivers is:
European drivers don't care if the brakes squeal- just as long as they stop the car.
American drivers don't care if the brakes stop the car- just as long as they don't squeal."
I'd think an open but capped fluid should be good for at least a year and possibly 2 as that's conditions similar to what fluid in car's expansion canister experiences anyway. Such a fluid is def better than a 5+ year old black one in the car's canister.
