We ran 3 snowblowers today at work for about 6 hours each changed the oil two years ago didn't bother this spring didn't run them last year.
Yes - it has a piece of pipe from the engine sump with a cap on it leading to a place where it is really easy to place a catch pan to collect the drain oil. This may be the easiest oil change in my entire OPE fleet. It's not a question of cost or effort to change the oil on this machine but more the fact that it sees so little run time. After 40 years of owning snow blowers I can honestly say that I've never run one for ten hours in a season. We haven't had much snow the past few years and this machine may not have ten hours of run time in total. That being said I will likely change the oil at the end of the season after running the fuel tank dry. We still have a lot of winter ahead of us so maybe it will get a real workout before then.On things that I can't live without - I would probably change it. 5 years its due. I am guessing it holds less than a quart, so its not a cost question. Does it have a drain plug?
We've had very limited snowfall here the past few years and there hasn't been a really large 24+ inch event since this machine was purchased. I believe it ran once last season plus once so far this season but not at all the two seasons prior. It's due for a change at the end of this season and there is an ample supply of 5w-30 M1 EP on hand. Up until now it was very difficult to see the oil on the dipstick because it was so clean but I can see it now. Perhaps the new mantra should be "if you can see it you should change it."FWIW, when I had my walk behind 2 stage blower, I changed it annually in the fall prior to the snow season. My thought was 20ozs of oil is a minor cost when I needed the beast to move snow. I now have a 2 stage blower for my riding mower. The oil is changed in the mower annually as well.
Just my $0.02
2x, when I do the summer storage routine, I make sure to run it until it gets hot enough to cook out moisture before the fresh oil goes in.I change it annually in mine. Snowblower engines are not hard on oil, and don't accumulate many hours (homeowner machines), but they also don't usually get the oil temp hot enough to burn off condensation.
Often when I drain the oil from them there is a significant amount of moisture.
