Time decide what oil to run in my air compressor for summer and winter.
It has 20w-50 Castrol GTX classic in it for break in and because I had no idea how hot it was going to get and it seemed like the most appropriate oil that I had on hand and was already open.
The air compressor doesn't get a whole lot of run time but I ran it pretty hard yesterday, filled it up with gas, used it on the sand blaster till it ran out of gas, never even allowed to unloader to pop the whole time. Then when it stopped I popped the oil cap off and stuck my probe thermometer in there, oil was 210f when it was 90f outside, which is perfect for a 30wt oil.
I figured 90f, running flat out, for a whole tank of gas, with 50wt oil that should be as hot as the oil will ever get.
I'm thinking just get some like a Briggs and Stratton 5w-30 oil unless there a just as good 0w-30 option.
But if there's a good 0w-30 for air cooled flat tappet engines that would be best Obviously the snow blower will be used in the winter and it's very likely I'll use the air compressor in the winter too.
