Ford says to change the gear oil in the diff on my truck every 100K (or something crazy like that), but the factory fill was synthetic. I have already changed the gear oil before (and it needed it bad) with synthetic, but this time I am thinking about switching to Rotella T gear oil which is dino. Would I have to change the gear oil more often with dino, or would a roughly 30K mile interval still be OK? Rotella T seems like it would be a good fit for the truck considering it does get used like a truck, but I do not want to have to change the gear oil every 15K.
The truck is a 2001 Ranger with a 7.5" open rear axle.
Also, the M5OD manual transmission in the truck requires ATF. How often should dino ATF in a manual transmission be changed? Every 30K miles? The only synthetic ATF I have found in stores around here is the "one fluid fits all" Mobil. I would feel better using a Mercon/Dexron III only ATF, but I can only find it in dino.
[ May 09, 2006, 10:13 PM: Message edited by: 01rangerxl ]
