How much should I overdose with Techron?
Can I put three bottles in one tank and speed up the cleaning of my injectors? 10.6 gallon gas tank.
Sure if you want to risk damage to a fuel system component. That's why there's specific directions on the bottle. More is not always better. Repeated doses are better.
Actually the bottle says refill with "up to 15 gallons" on the regular size bottle of Techron. There is no minimum amount listed for gasoline. I'm not arguing because I don't know if it's harmful or not.
Likely no one cares but the Cherokee I mentioned earlier just ran a half gallon of used motor oil through it mixed with about 10 gallons of gas didn’t effect it any and it didn’t die, more just wanted to get rid of the old oil gona probably run some Techron through the system to clean whatever that may have caused
