What OTC Fuel injector cleaner should I try?
Apple Valley, California
I have 3 restricted injectors in my Jeep.. Figure I can try a cleaner although I don't have high hopes.
In the past I have used Techron. Even double dosed a tank or 2. Anything else I should try?
I prefer the RedLine SI-1. Available at O'Reilly's and on Amazon. Or BG-44K if you have access to a source in CA.
It is eating the same 3 spark plugs over and over. #2,#4,#5. Fuel trim is weird and power is down. No vacuum leaks.
Do the injectors ohm out good? It's pretty rare for a driven vehicle to gum up a firing injector without something underlying like a current ramp issue.
my 2c
Try 1 Berryman b12 2 back to back fill 2 gumout high mileage regane then 3. redline s-1 if that didn’t work then manual cleanings needed
Seems crazy to me that a forum dedicated to fuel and fuel additives has so many people being smart asses and saying "skip the additives and do it properly" like ok thanks Chad, but that's not the question!
Such a weird thing to care about on THIS forum.
Not an expert but you can try Berryman's B12 for a tank and then try something with PEA the next tank. BG 44K, Amsoil PI or Redline SI-1 would be my choices in that order. If that doesn't work, then try a more extreme measure. I wouldn't double dose just based off of stuff I have read. Make sure you run each tank as low as possible and as mentioned, let it sit for a while too as opposed emptying the tank asap.
