I'm still trying to get my head around why Toyota is so finicky about measuring ATF at operating temps.
Torque converter drain back.Anecdotal evidence-
Recently I acquired a 2015 Toyota Tundra with 147k miles. No history of transmission fluid exchange.
I did two spills and fills. The Tundra sat overnight before the spill and fill. Both time the tundra spilled a bit over four liters into a catch container.
Today I did another spill and fill. Only difference, the Tundra was outside overnight, and I pulled the Tundra into the garage for the spill and fill. The spill only dropped three liters. Outside temperature during the spill and fill today was 95 degrees Fahrenheit. Why the reduction from four liters to three liters? Increase in transmission temperature from outside air, and under one minute of engine running? Increase in just outside air? Or, simply the transmission slowly leaks fluid from places like the torque converter into the transmission oil pan after extended sitting/ non use?
The Tundra is in the garage tonight, I will do another spill and fill in the morning with the transmission cold, and see if four, three, or another quantity spills.
You're propping the t-stat open for final check, yes?Anecdotal evidence-
Anecdotal evidence-
Yes,You're propping the t-stat open for final check, yes?
The wire clips that retain the front caliper slider pins work really well. I keep one (trimmed shorter) in my service cart now and consider it just another tool. That said, anything that fits, works.
If you end up wanting to drop the pan, I’d hit the bolts with Kroil before even attempting it. Let it soak for a couple days too imo. IF you end up dropping your pan, post what you see.Yes,
Just did another spill and fill this morning.
Fourth spill and fill completed.
The big question, to remove the pan or not. I inspected the bolts this morning, no sign of corrosion/ rust in the threads. I read about the bolts breaking during removal and make sure one " knows what they are exposing themselves to". The spill and fill may be fine, but it looks more likely than less likely the fluid was never exchanged prior to my purchase (147k miles).
or 1.5mm allen keyYou're propping the t-stat open for final check, yes?
Exactly. I consider those precision instruments and don't like risking loss or forgetting one as I cannot stand an incomplete hex key set. Thus began my search for something more readily available and expendable.or 1.5mm allen key
