GM platinum will last 100,000 miles. If not sure, remove one that is easy to get at. When you replace, use the AC Delco Iridium, they will last much longer, plus the iridium tip provides a better spark. I only use iridium - Denso, NGK, Champion, and AC Delco are best, Autolite XP is cheap, they also work, but watch the gap on XP, examine the tips in the store BEFORE you buy - the ground electrode is often off centre, and requires bending with the gapping tool to line up.
