- Joined
- Dec 20, 2022
- Messages
- 300
Anyone have experience with GM's plastic oil drain plug? Was used in the 2.0T and 2.7T engines, with the 2.7T switching back to a metal pan.
Seems like a better design than Ford's and VW. How many times do you think the gasket can be reused, just until a small leak is seen, probably 25 - 50k miles? Biggest downside is probably the oil change itself, after pulling the plug. Only 10-15 seconds and 5 qts end up on the floor because the pan can't keep up. Thoughts?
