Back to the magnet thing........
I can see the validity in it, I mean many transmissions have them stuck to the pan.....further some factory pans have bosses in them to raise the magnet off the surface and increase their holding surface area.
I think the issue is the specificity of the test to validate the results, meaning you would have to run several engines with the same oil, fuel, load, etc, blah blah blah........
I have changed my opinion to the side of maybe it does something worth while, but not sure that it makes a difference in engine life.....
Maybe they are intended to help removal manufacturing debris from the bottom of the pan. Most stuff is so small I can see it not settling to the bottom..........not sure.
