Spark Plug Replacement Intervals - Why?
Where did I say that I didn’t want to do it? I asked for someone to clarify what the potential failure mode effects of eroded spark plugs are. All I got was a bunch of ways of saying because the manual says so until one person bothered to actually address my question. Since then the thread has turned into practically all condescension and strawman comments about how I must not do any maintenance.
For a site that’s supposed to be about helping people understand how things work, there seems to be an awful lot of gatekeeping against anyone who asks the wrong question.
Like I said I meant no offense. It doesn't seem like you are taking the advice that was given. Maybe you are I don't know? It's a touchy subject for all of the technicians on here I'm sure. We have seen what happens when customers do not keep up with maintenance. It ends up costing them a lot more than if they just did the maintenance. Had a customer years ago burn a valve and trash the cats from not replacing spark plugs. Another common one is engines destroyed from not doing timing belts at the correct intervals. Have a good day 😊
Really? Because there’s a response by me on the first page where I thank SC Maintenance for giving me a legitimate answer. Since then, it’s been nothing useful.
I like how you edited that one sentence out of the whole response. I'm not going back and forth with you over this. Have a good day ☺️
I had the ceramic insulator on an old set of plugs get brittle and crack from age/heat once. On one of them a piece broke off and almost fell into the engine during removal. I caught it. But man that would been a nightmare to deal with. I don’t run plugs out after that experience; before or at the recommended interval only.
My Chevy LS3 V8 ran great at 70,000 miles. My son had the same car and just changed his plugs @ 95,000 miles per the maintenance listings. They looked BAD! So I took mine out. Also BAD! Most had huge gaps and 4 pretty much had no center electrode at all. Pic is one of the worst ones and a new plug. I’m changing this new set @ 50,000 miles or sooner.
It isn’t even worth the discussion on a 4-cylinder IMO. 10 minute job.
Now on a car that you’ve got to pull the intake manifold and a bunch of other stuff to do it? Let’s talk.
